2003 C4S
the gear shift used to be very snug but as time goes by it gets looser and looser. Is there any way to tighten it up or I need to get new assembley alltogether? if yes, what are the parts' numbers shich i would need? thanks
Standard factory shifter or short shift option?
The factory shifter does not have any adjustment for looseness - only for gear throw. You could have a worn bushing like the one Tool Pants showed here.
standard factory. it feels that all those plastic things that hold it are loose, could not see the bushing, but will check.
