Anyone that knows what the function with this plastic tube ahead of the turbo charger at the driver side?
It's nothing at the other side.
I mean the little plastic tube attached on the red ring.
It's the same red ring on the other side but no pin for connection.
The plastic house is going up to the engine compartment.
(I saw this then I change the sparkplugs and got intressted what the function was for.)
At first I thought it was the air pressure sensor but it does not look electrical (or the right shape). If that is just a hose connected to it then perhaps it is the oil breather hose from the oil system heat exchanger (burns the vapors for emissions).
