We have a member who took his Boxster in and had the fault codes read and it came back 1128 AND 1130. In combo is that the classic MAF fault sign? This is on a 2.7L Boxster (2000).
TIA!
TIA!
There is a TSB for MY97 - MY00 Boxsters that states a P1128 and P1130 codes are potentially caused by an air leak in the oil filler hose. P1128 by itself is usually a faulty oil filler cap seal. Let me know if you want a copy of the TSB.
Yes if you have a soft copy I can pass on to the owner that would be great. He has an aftermarket K&N intake and filter and thought it was related to that.
