What is actually the difference between the two? Do they have the same dimensions ie. thickness, mounting holes etc? Also if they fit a standard C4S do they provide a braking improvement?
Many thanks,
Damian
Many thanks,
Damian
I think the C4S/TT big reds are a larger diameter, better stopping. If you want to upgrade for the track, just throw on some pagid orange pads on yours, hand of god stopping at the track.
Chris
Any of these options will require wheel hub changes also.
GT3 mk1 (and perhaps others) calipers will require 5 mm spacers so the wheels won't rub the calipers.
C2 and C4 Rotors (steel)
Front: 318 mm
Rear: 299 mm
C2 and C4 Calipers
4 piston
GT3 mk1 Rotors (steel)
Front: 330 mm
Rear: 330 mm
GT3 mk1 Calipers
4 piston
GT3 mk2 Rotors (steel)
Front: 350 mm
Rear: 330 mm
GT3 mk2 Rotors (PCCB)
Front: 350 mm
Rear: 350 mm
GT3 mk2 Calipers
6 piston
TT Rotors (steel)
Front: 330 mm
Rear: 330 mm
TT Rotors (PCCB)
Front: 350 mm
Rear: 350 mm
TT Calipers
4 piston
GT2 Rotors (steel)
Front: 350 mm
Rear: 350 mm
GT2 Rotors (PCCB)
Front: 350 mm
Rear: 350 mm
GT2 Calipers
4 piston
So to clarify, there is absolutely no difference between the rotors?
Yet there is a different part number and a price premium (in the UK), Porsche GB claim it's a Motorsport part.
I've got Pagid RS29 (Yellow) fitted on my C4S and stopping power is phenomenal :) just have to replace the rotors because of a few little cracks around the holes.
Damian
Well, the GT3 mk1 front rotor (996 351 409 91) has a Motorsport part number (ends in 91) and the TT front rotor (996 351 409 02)has a regular part number. The specs same the total pad area and the sweep areas are identical also. I do not know if the material (hardness) grades are the same or not. The GT3 was intended for track performance and the TT really wasn't.
