I have an 03' manual C4S and am about to purchase the revised H&R coilover setup. The problem is that there is no listing for a C4S coilover---it is only offered for a C4 or a Turbo.
I originally purchased the H&R coilover set up for a Turbo since the C4S has the same suspension (correct??) but when i double checked with H&R, they told me to purchase the coilover for the C4. This didn't make sense to me and got me worried so i returned the **** thing.
Can anyone tell me which one i'm supposed to purchase?? I original thought the Turbo setup would work but the H&R tech told me differently...Can anyone clear this up?
I also purchased the H&R sway bars for the Turbo with the intention of putting it on my C4S, since they don't make one specific for a C4S. Will this work or should i just return these also?
I have 24hrs before the 20% coupon for Performance products expires so i need help ASAP! thanks
apparently i need the C4 setup...does anyone know if the H&r sway bars will work?
according to carnewal...the gt3 sways work but i haven't heard anything about the H&r sways
Loren,
I ended up getting the Pss-9 setup for a C4 (to put on my C4S). I figured if i needed the C4 setup from H&R and H&R makes the springs for the Pss-9 setup (what i hear) by implication, it would mean i need the C4 setup from the Pss-9. Can you confirm if this is the right one for me?
The parts lists I have do not show PSS-9s for C4S... so you are going to have to rely on Gert (Carnewal) or another PSS-9 source.
I can tell you that the factory swaybars are the same from a C4 to a C4S but the shocks and springs are different. And, they are still slightly different that a TT.
