Do anyone know how to remove the door storage lid on a Boxster?
Do I have to remove the entire door panel in order to take off the lids?
Please advice
Edited by Thomas Ching
The fastest way is to push the pin out on which the door pivots. If you look at the both hinges you should be a pin which the door pivots on. You can push those right out and just the lid will pop off.
Or you can remove the door panel and remove the whole assembly.
Thank for your advice, have you or anyone you know successfully remove the pins from the door pivots?
