Has anybody done this kit install and is it any good?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...AWNA%3AUS%3A112
The 3 Main Components of the HID System
BULB : - The Xenon Gas and mercury Metal Halide Salts existing inside the light emitting tube causes the molybdenum electrodes on both sides to plasma discharge and create energy, which in turn produces light. In laymen terms…These suckers are Bright!
IGNITER : - This is an electronic amplifier that receives electric current from the ballast and boosts voltage to ignite the Arc Light Source in all environments. It initializes plasma discharge within the source by delivering a high-volt pulse to the electrodes.
BALLAST : - This is an electronic control unit used to initialize arc and supply a stabilized power supply to the bulb and igniter during normal arc conditions.
PLUG-N-PLAY
Step by Step - Highly Detailed Instructions included with every Kit! Installation is a Cinch! We even include pre-drilled, OEM, Headlight Backing Plates to make your job even easier! No expense Spared.
