My dealer indicated that the coolant tank in my 99' C2 has a slight leak at the seam. I also have a couple of rattles in the car.
Questions:
1) I have yet to see any evidence of a leak from the coolant tank. I check the coolant level and it doesn't seem to go down. Is there any way to pressure test that system for a leak?
2) Since I don't yet have an owner's manual, can someone please tell me if I should be checking the coolant level with the engine cold or warm?
3) Does anyone know any good private Porsche mechanic in Tampa?
4) There is a rattle toward the right top front of the dash that begins about 20-30 mph, and continues, and continues, and continues....... Any known issue or fix?
5) There is also a rattle under the middle of the dash, like something is loose. Any known issue or fix?
6) Lastly, thank goodness ;) , is there any easy fix for the wind noise from the area around the front edge of the driver's side door window (i.e., the A pillar)?
Thanks much.
Dean
Yes., but you need special tools to control the amount of pressure. If your dealer says it's leaking they should have done the pressure test. Many dealers will replace the tank for free since this is a known problem and Porsche has changed the tank 3 or 4 times.
The coolant should be checked when the engine is cold and the car is level. The fluid level must lie between the "Min." and "Max."markings.
Sorry, perhaps someone else can reply on this one.
If the noise is actually at the front windshield then there is a TSB to replace the windshield seal. If the noise is in the dash there is a 9 page TSB that a series of fixes depending on the problem area.
Do you mean front console or dash? If anything in the front center console has been changed then it is likely that something is loose. If it is the dash then TSB I mentioned above should cover it.
6) Lastly, thank goodness, is there any easy fix for the wind noise from the area around the front edge of the driver's side door window (i.e., the A pillar)?
There are a couple more TSBs that cover A pillar noises. Most of them are for creaking or cracking noises not wind noise. Have you checked the weather stripping around the window? and are you sure the window is all the way up? If not, there is a special adjustment procedure to raise the window all the way up.
  • 2 months later...
