My remote quit working. It's because the plastic dimple that presses against the electronic switch is worn down. I just need a new cover, not the $200 key itself. Anyone got one or know where I can get a used one? It's a one button remote.
jp
jp
There are frequently remote key heads available on Ebay that go cheap due to the fact that they have no bar code tag with ID number (for mating to the car's computer).
If your problem is truly limited to the physical condition of your key head, you could buy one, move your electronics (remote and immobilizer) to the new head, and you would be in business without having to go through any mating at the dealer.
Kim
2000 Cab
Or... you could just read the Porsche TSB 1/05 9662 Design Key (dated Jul 29, 2005) in the TSB section... ;)
The TSB is here in the Carrera (996) TSB's (Technical Service Bulletins):
http://www.renntech.org/forums/index.php?&...rder=asc&st=200
I believe that when they say that it doesn't work for a convertible, they are talking about a Non-US version that may have a third button on the remote for the top.
I have a couple of one button key heads for a 996. Had to replace mine when the electronics went out. Let me know if you still need one.
  • 2 months later...
