I would like to put 19" RH wheels on my 1999 C2 coupe (NB) and later on lower the car with a new set of springs. Will the 19" wheel clear the body or should I stick with the 18" since I will be lowering the car at a later date.
You should have no problems. This is the setup that I have and the wheels don't rub at all.
Hw,
Whether your wheels will fit has little to do with the diameter. It has everything to do with width, offset, tire size, ride height and camber.
Jim
Im putting on a set of Iforged Rims next week 19s and im also lowering the car at the same time... In my opinion you have to lower it with the 19s if not its not going to look good. There are some pics in www.Iforged.com of 911s lowered with 19s.. Cant go wrong dont do the 18s if you have the option of going with 19s you will be happy with those.
These are the rims im getting my car is a black cab though.. http://www.iforged.com/showroom/view_photo...bum03&id=9961_G
Hope this helps if you want pics of the car when its lowered give me your email address and i will sent them.
