Hi, I am lookin for the best product in the market to get the best look for rear plastic window.
Which to choose, Plexus, Renovo, Meguiars ????
Best regards,
Edited by valcax
Best regards,
Plexus seems to be the most used. It's what I use.
Best regards,
if Plexus won't clean it use Flitz and a microfiber rag(yes seriously) I've been using it on the dodger of my sailboat for years and it's the same type of plastic, having just bought my 986 and it having a foggy window at purchase, Plexus wouldn't clean it, 1 pass of Flitz brought it back to 85%, another to nearly new
if you don't know what Flitz is, it's a metal polish that's non corrosive, non abrasive, and has a protectant in it, it's the best stuff in the world
edit: here's a link http://www.flitz-polish.com/?source=gg&cam...name&term=flitz
Edited by stumpjumper
Best regards,
Microfiber towel is the way to go.
  • 8 years later...
I don't know anything about Flitz but if it is a "metal polish" why would you use it on plastic rather than a water-based, specialist plastic polish like Renovo's?  You don't know what's in Flitz so why risk damage that you may not see for some time?  As a general rule, plastic windows should not be cleaned with domestic cleaning products  that are intend for use on glass or other hard surfaces.  The same rule applies to plastic film window tint - my tint warranty (fine print) actually specifies cleaning with warm water only!
Actually Flitz is designed for plastics.  The text below is from their website:
Color/Finish:
  • Removes oxidation, tarnish, rust, water stains, heat discoloration, lead and powder residue, scuff marks and more
  • Easy to use cream formula Our signature product. A concentrated cream that is unsurpassed in its ability to clean, polish, deoxidize and protect. Nothing works faster, easier or better. Use on: brass, copper, silverplate, sterling silver, chrome, stainless steel, nickel, bronze, solid gold, aluminum, anodized aluminum, beryllium, magnesium, platinum, pewter, factory hot gun bluing, painted surfaces, Formica , cultured marble, Corian , glass, Plexiglas , plastics, fiberglass, Eisenglass, and Armatel . Removes: tarnish, rust, water stains, chalking, lime deposits, heat discoloration, lead and powder residue, oxidation, bugs, tar, oil, fingerprints, tree sap, bird droppings, graffiti, dyes, black streaks and scuff marks. Not for: Electroplated Finishes.
Edited by kbrandsma
