I've read about this fault comming up as a result of a problem with the seat belt switch. Can anyone explain what the fault in the seat belt switch is? It's comming in after 100K miles. Could it be dirty contacts?
Both the buckles and and underseat wiring connectors corrode. Porsche issued a TSB that replaces the buckles and connector contacts with gold plated connections and ground point is modified. To do the fix yourself you will need pin removal tools and experience with a soldering iron. Takes an experienced tech about 2-3 hours.
The 5 page TSB is available for viewing here by Contributing Members.
