I have a 1999 C2.
About 70 miles after changing the oil in my car with a mix of 5-30/0-40 Mobil 1, my check engine light came on. Ever since I changed the oil, I have had some idling issues as well. When idling, the car will go through a few periods of revving (always below 1K), and then it will eventually settle down and stay idle at a specific RPM. (This usually takes about 3-4 cycles before it settles down.) Same is true of my oil pressure gauge -- it moves around slightly when idling instead of cycling like my rpms.
Right after changing the oil in my car, the car came up clean but it had a lot of problems idling... worse than it is now. After some driving, the hard idling went went away -- now I am left with the "cycling" that I describe above.
I have check the oil level and the oil cap (it is on tight).
I also am sure that it is not the MAF as I replaced that recently (few K ago).
Any help would be greatly apprecited.
-hjk
Is the o-ring in the oil cap?
You will need to take the car to Autozone or another shop that will read the codes for free. Then report back here what (all) the codes are.
