My '02 996 Carerra has a fast clicking left turn signal now that the weather has turned cold. Also, the rear amber bulb is out. I believe replacing the bulb will cure it. I believe the flasher is under the dash if it needs replacement. I'm sure this is a common problem. Any tips welcome. Thanks.
Replacement of the bulb should fix the problem.
