I have a Arctic Silver 1997 5 speed Boxster 2.5 all stock with 87,000 miles. Today I damaged the green plastic housing around the tip of one of the fuel injectors. It all started when trying to replace the long oil separator vent line running across the engine. I don't recommend anyone tackle this unless they are prepared to disassemble the entire top of the engine. ;)
Question
Is it advisable to replace just the damaged injector or should they be replaced in sets?
Adam
STL
