The light in my rear defrost switch is not coming on ('04 C4S). I wanted to do a bit of diagnosis before I bring it to the dealer. In particular, I want to make sure that it is not a problem that I caused when I had the relay and fuse carriers out to install PSE. I was wondering if anyone knows which relay is used to control the rear defrost (I am assuming it is relay controlled). I was also wondering if there is a wiring diagram available that covers this.
Before someone asks the obvious, I did check to make sure it was not a burnt out fuse!
Pete
Pete
If you PM me with a Email address I will send you wiring diagrams and relay layouts from my manuals. Can send them as a doc. file you can open in word.
