PCM 1 CD Drive / Navigation Unit Removal
Removal of Porsche Communication Management CD-ROM / Navigation Module from center console: Tools Required: 1. Blaupunkt/Bosch-style standard DIN receiver removal tools 2. Small flat-blade screwdriver or dental tool Procedure: 1. On each side of the unit, there is a small vertical plastic cover that must be removed first. Grip the cover with small fingers, or very gently get a soft tool around the edges to get it moving out. Remove these covers and set them aside. Note: there are no ba
  • 2 years later...
Great Lesson. Can I remove my PCM1 CD Drive without affecting any of the other systems? Thought I would use the space for a useful Nav unit.
Best regards, Milesy2
  • 5 weeks later...
Great job, thanks !
I have the same question: does the removal of the CD nav unit will affect the the PCM1?
I understand that, of course, the navigation module of the PCM will be useless, but what about the on-board computer?
I mean, the distance calculatore, the tank autonomy and so on???
Does someone know if we can plug a new music CD reader (like the CDR-21) and control it with the PCM1 unit?
Thks
