Hi Guys,
I was wondering how can I replace the bad headlight bulb( littel park light), do I have to acess to headlight with removing the cover inside the fender? Thanks in advance to any feedback.
Bill
Miami Beach, FL
Are you talking about one of the three lights in the main housing (high, low, fog) or the side light on the fender?
The park light inside the main housing. I checked inside the trunk but I couldn't find a way to get there.
Thanks for the reply,
Bill
Page 174 of your owners manual will show you how to remove the headlight housing using the tool supplied in your toolkit (behind the spare in the front trunk). Page 177 will show you which socket has the parking bulb. Should be about a 5 minute job. :D
Great Help guys, but the bad thing is I don't have the manual with me, (in our winter house NY) I don't know why I need the manual at home but don't ask me. So is it possible to direct me to the right direction, Thank you very much for the help.
Bill
Thanks again, I figured it out with your hint, I used the little tool to remove the housing and remove the bulb, now I need the find the replacement one.
Thank you guys....
Bill
