  • 2 years later...
  • 4 weeks later...
EDIT. SOLVED.
YMMV. On my 99' 996 C2, here's what I discovered.
The window up/down switch uses pin 3 for ground and pin 5 for the night time illumination. So if you use a window switch be sure to observe these different pin-outs.
Also according to the work shop manual pin 3 on the switch is for ground, NOT pin 4 like in this DIY!!!
Again, your situation might be different based on your model year, you should always confirm with a multi meter and work shop manual.
Hey all. I just did this mod using a window switch. It works great, but the dashboard illumination doesn't work right when I turn the lights on.
With just the illumination wires plugged in the led inside the switch comes on fine when I turn on the car lights.
However as soon as I plug in the three spoiler wires to the switch the spoiler control doesn't work until I unplug the two illumination wires.
I have a second window switch and it does the same thing.
I triple checked all of my wiring.
Does anyone know (or guess) that perhaps this is because I'm using a window switch and not the "sanctioned" spoiler switch with part numbers referenced in this thread and DIY?
TIA!
Edited by logray
  • 5 years later...
  • 6 years later...
Great article. I’ve just followed it for my Gen2 and a couple of the wire colours seem different it was easy enough to work it out. All working nicely.
Thanks for posting this.
