Guys does anyone know what I need to use to remove this panel on a mk2 car? I have an 02 C2, removed the (only two?) plastic plugs without a problem, but 4mm, 5mm, 6mm hex socket can't even get a bite in there!
It's 5 mm allen head wrench on 2002 and newer.
Hah that explains it! I'll go give it a shot right now Thanks Loren
UPDATE: 5mm allen wrench worked thanks again
Edited by htny
  • 6 years later...
On a Mk2 car, how do you get to the rear screw? In order to get the hex wrench in there deep enough, I'm going to have to remove the driver's seat!
