the seat itself is a no brainer, just held on with velcro but how do you remove the seat backs? anyone with instructions?
You must remove the swivel bracket mounted on the outside wall at the bottom edge of each back seat. It is held in with a fastener called a "triple square", 8mm. (Thanks to Loren for that info and the source):
http://www.sjdiscounttools.com/sk19704.html
This looks like a many-pointed Torx.
After you remove the fasteners on this swivel mount, you can slide the bracket and the outside edge of the seat back forward, and simply pull the swivel rod out of the inside bracket, which is on the center tunnel and shared by both seat backs.
Hope that helps.
Kim
2000 Cab
