Is there anyone out there that has any "tips" on adjusting the height of the exhaust tips? I need to bring mine up a bit. I hope I do not have to take the rear end apart to get at the top side of the muffler.
The attached picture shows a muffler with the 'S' aluminum spacer. 4 bolts attached to the transmission (not shown), 2 nuts to studs on the bar spanning the top of the muffler(1 nut removed in photo). As you can see, there is some side-to-side adjustment. Up and down adjustment is only a small amount possible by loosen-push up-tighten of the bolts.
Edited by adsach
Great Picture,
This is a good view! Food for thought, I will see if I can get at these bolts?
Question, the two round cylinders have allen fittings in them. Would these have anyting to do with the up and down adjustment?
Thank you very much!
Max/Bruce
Great Picture,
Max/Bruce
Interesting idea about adjusting the round thingies. They look just like motor mounts to me, I didn't look to see if they are adjustable. I would guess they are not.
New Idea :lightbulb:
It may be that what you want to do is adjust your bumper cover position rather than adjust your muffler position. I didn't find a link to instructions, but you basically take off the spoiler and loosen screws under the spoiler and underneath the wheel well liners to remove or shift the bumper cover around.
