Hi, new to the forum.
I was wondering if the rear spoiler warning light can be de-activated by jumping the connector for the 997's?
I've read the post for 996 is it the same? Installed a GT2 wing and disconnected the harness for the rear wing, problem is at speeds the warning light comes on.
Any help would be appreciated! :help:
THANKS!
Jumping - probably yes but the TSB does not give the pins they say just use the new harness.
Aerokit wiring harness:
997 612 670 71 Electric wire harness - retail $46.37 (as of Oct 2005)
Thanks Loren! You are awesome as usual!!! :clapping:
what is the latest update on the wiring harness. I talked to two dealership in Va and they were clueless. If you purchase one please let me know where I need to get one for my car as well. thanks
The harness is a Porsche part. Any dealer that does not have it and won't order it for you - is not doing his job. If you can't get it locally then call the folks at Sunset Imports (Porsche Parts at Dealer Cost.)
