I checked out the DIY oil change and it did not mention draining oil from the turbos, Does anyone know the torque specs for tightening these bolts and I assume they have crush washers. Thanks Mike
Oil drain plug on crankcase - 70 Nm (52 ftlbs)
Oil drain plug for oil container - 60 Nm (44 ftlbs)
Oil drain plug for turbocharger - 30 Nm (22 ftlbs)
Oil filter cover - 25 Nm (19 ftlbs)
Thanks Loren
