When I pulled into the garage tonight I noticed an abnormal buzzing sound coming from the front of the car. After 74,000 miles in the car I am pretty familiar with the different sounds the car makes and this one is new. The sound is not present when I turn on the ignition switch but begins when I start the car. The buzzing is loudest at the front fender wells on both sides of the car. I opened the front trunk and the sound was not coming from that area.
The sound is not related to the radiator fans since it is present when they are on or off. No fluids leaking from the front end. The coolant and power steering fluid levels are normal. I tried cycling various items like AC and traction control but the buzzing remains. I was thinking it may be the fuel pump (I am familiar with the “normal” sound it makes) but I thought the buzzing would be louder when I opened the trunk.
Has anyone had experience with this problem?
