I posted my instructions via my experiences installing the bar in a GT3. They are located in the DIY forum....For those interested...
Safety Device makes the best roll bar or cage other than factory cage. Finished nice with black powder coat, and fit well. Plates have to be welded in and then roll bar is bolted to plates. All for about the same cost as the bolt in factory bar which is mostly cosmetic with little strength.
Jim
You're going to weld on that brand new shiny white GT3??? Any other GT3's around Milwaukee??
Yes, welded in bar ,Gt3 cloth seats, Schroth 6 point belts, These few touches are needed to track the car next year. Parts should be installed by 1st of year. hope to be ready for Sebring in Feb.
Jim, with that stuff installed, you should take it out to that Nevada "race" on the open highway. To run the higher speed classes you need a bar and belts- that sounds like it would be a blast, and a lot safer than the back roads in Wisconsin on the way to Road AMerica! And a lot easier on your driver's license. As far I know, I don't think there is another GT3 in Iowa but who knows. I did get GT 3 for a plete though...
Little strength???? Strong enough to keep the roof from crushing in the event of a roll over...Not doing the 24 Hour at Le Man here averaging 170 mph.... :drive:
Good enough for some PCA classes. Besides if you are doing any of the serious classes you need a roll cage...A little overkill for 95% street driving , IMO
see PCA rule appendix A
http://www.pca.org/pca/clubrace/docs/pca_rules_2004.pdf
Edited by rockitman
I am not knocking your choice, just did not know if you knew of other options. Sorry I do about 14 DE events a year so to me its very important.
This was a big controversy in PCA Club racing last year. The rule states "The
roll bar must be securely mounted to the floor and/or longitudinal members of the unibody with the top of the main hoop at least 2" above the driver's helmet when the driver is seated in the normal driving position. The mounting area of "bolt-in" roll bars must be backed by a plate of a size equal to that of the upper mounting plate with a minimum thickness of 3/16". Bolts must be grade 5 or higher."
This requirement of a backing plate effectively eliminates most bolt in roll bars such as the Tequipment bar or the DAS-Sport bar from use in PCA Club racing. The factory Club Sport bar or the Safety Devices bar are legal because they both use backing plates that are welded to the underside of the car.
Karl
Well that kind of sux...But no real problem...my beauty will not see the light of day of wheel to wheel racing(There will be the occasional DE's or rented track days)...I will purchase a used cup car for that purpose after I make the move to racing in a couple of years. But before that, I will start my race career in a mini cooper class or one of the scca tuned club cars and get some real race experience before tossing around an expensive porsche on the track in competition...
