I recently completed the OBC hack using a footwell light switch (996.613.980.00) and the Computer functions are no problem. However, I have not been able to get the lights on the switch to work. I am not concerned about the bright light that would show that the footwell light was on, but rather the back lighting that goes on with the headlights/dashlights. I also recently completed the dash spoiler switch mod and got that switch to light up per the DIY. But when I used the same wiring configuration on the new switch no luck. Does anyone have a solution?
I think this has been covered before, by Sandy. For some reason I thought it could not be done like other switches because the footwell switch was internally different due to the LED indicator. But here is some info. Looks light you need pins 3 and 4.
http://home.comcast.net/~kilsen/boxster_gdo.htm
http://www.whiteson.org/boxster/mods/obc/liteswitch2.pdf
Toolpnats - Thanks for the help!!
