I've got a bit of a rattle from the instrument cluster. I was going to remove it to apply some felt between the parts to damp the noise and found that one of the two bolts holding the cluster to the dash was missing (wonder why it was rattling right there...). I'd like to replace the bolt rather than remove the unit at this point to see if it solves the problem. The manual specifies that the bolt is 5.0 x 30. Does anyone have an idea of what the pitch is? I picked up a 5.0x0.8 30mm and it doesn't seem to want to thread...
Shawn
