The fabric on my convertible top has separated from the arm the raises and lowers the top. The separation is located near the top of the back seat.
The top appears to be glued to the metal frame near the top of the back seat. There's a piece of fabric that is attached to the unglued piece by velcro.
Has anyone tried to reglue the top. If so, what did you use.
I have tried two sided tape with little luck.
3m makes some great velcro strips that have a strong adhesive on the back of the fuzzy side. Make sure you clean all old adhesive off of EVERYTHING or it will probably happen again.
