Hello everyone, first timer here on the RennTech board. I own a '97 boxster, and am an avid do-it-myselfer. I noticed my radiator was leaking, so I dropped the bumper in an attempt to locate the leak, which I did. It was coming out of the front passenger side of the car, from the radiator. Well, I epoxied the leak, and thought everytying was good. Put the bumper back on, and now the water temp sensor won't move. Unless I'm mistaken the water temp sensor is below the air filter correct? Not off the radiator. Any help would be appreciated, because I'm stumped, and my porsche will be off the road until this can get fixed. Thanks.
Edited by Porsche_Poser
Assuming it was working before you took off the bumper then I would go back over your install and check that you have not knocked something loose. And you can check the fuses too though that is not likely the problem.
