i started noticing a problem when the window rolled up and down it sounded like sand paper grinding my window inside the door... after that, it only rolled up and down an inch.. then today, i could hear the window motor going but the window didn't move, and the window just fell into the door.. so now i can slide the window up and down very easily with my hand..
my question is, is this a common problem with a 99 boxster? also, how hard and how much does this cost to fix usually? thanks!
Its pretty common for the window regulator to fail, in fact its pretty much the only thing that goes wrong with the windows period. Seems like most places charge around two and a half hours for replacement.
