Assuming you did not take the steering wheel off or remove the seats with the battery connected. Then this is pretty commonly the problem:
TSB 1/04 6924 Airbag Warning Light Comes On: Fault Codes 46 and 49 - dated 7-21-04 gives full instructions on how to replace the drivers side and/or passenger side seat buckles with new ones. About 2-3 hours to do both.
(Also common problem in pre MY04 Carrera, and Boxster as well as TT/GT2/GT3.)
Do u know the part #'s for the buckles?
It's not that simple - it is a 5 page TSB. You have to modify the wiring that is on the car wiring harness. Some dealers will do this fix as warranty or goodwill.
