I complete the wiring for the mod to install switches for the engine compartment fan and the rediator fans found on Renntech. This involves running wires from the ground legs (#85) of relay #8 for the engine compartment fan and relays #20 and #22 for the radiator fans to a switch location, and another to ground. In orfer to try for a Factory look I elected to use footwell light tip switches (996.613.980.00). However, the fans only run while I hold the switch down. Apparently there is no ON and Off position. Any suggestions or solutions with these switches or are the just incompatible for this use?
