I got a call from my dad today asking me if I could search some of the forums to try to diagnose a problem that just popped up with his C4S. There is a rattle coming from the rear end of the car, my dad thought it was the exhaust at first (jokingly blaming my installation skills of the PSE :) but it might be coming from the engine. He says it sounds like a pebble in a tin can and only occurs when be blips the throttle or take a right hand turn. There is no oil on the floor and the exhaust seems to be on there very securely. Has anyone experienced this problem or possibly know what it could be?
Thanks for the advice.
A4EP
2002 C4S, SG/BLK - 6-speed, Heir
Was the noise present before the PSE install? It sounds like you may have some loose debris inside your sport muffler.
Edited by RJFabCab
No, the rattle just developed and I installed the PSE over two months ago so I don't think there was debris inside the muffler since it has just started to rattle.
I may know exactly what this rattle is.
On some 911 C4S coupes, the brackets that hold the exhaust pipes break or loosen over time and make the rattle noise your now hearing. Your dealer will be able to fix this very quickly under warranty.
When you get about 5K to 8K miles on your C4S, this might start to show-up.
Take it to your dealer and they will either tighten the brackets or weld them together.
Although this noise is annoying, it does not harm the engine or your exhust system.
I hope this helps,
Mark
Mark, very interesting. The car is at just under 8k miles so it is in the range. Which brackets are you talking about? Having installed the PSE I hope I didn't overtorque anything now. Is it the braket that holds the main part of the exhaust on or just the small bracket that holds the exhaust tips on to the exhaust pipe itself?
I can just see it now, if it is the install I will never live this down :) Please let it be the engine, please please please :) :) :)
A4EP
The following two part numbers were ordered by my dealer.
They solved the problem completely.
FP-NUMBER DESC
996-111-352-02 Exhaust Pipe
996-111-351-02 Exhaust Pipe
Ignore the description given by Porsche. These part numbers are not really a pipe. They are new pipe brackets that replace what you currently got.
I hope this helps,
Mark
