Hi Thanks in advance. I happened to drop a tool in my engine compartment and have been searching for it for the past two days. I finally found it sitting under the a/c compressor. I had a bright idea of trying to move the a/c compressor to get to this tool. I found out that the compressor is held in by more than 2 bolts. I removed the two bolts but couldn't slide it out so I've given up on that idea and need to torque down the two bolts I've removed. Does anyone have an idea of the torque values for these bolts? Thanks!! By the way I was able to retrieve the tool from between the intake runners. What a job! I drive a 2004 c4s coupe 6 speed
Compressor bolts - 17 ftlb. (23 Nm)
Hi Loren, Thank you very much! I really appreciate having a great resource available to answer our questions. Mahalo, Rayton
Edited by puako
