Hi guys. Im sure you've seen this many times. Ive done my search but found many different answers. :help:
Basically which spark plugs should we use. Ive got a 2002 Boxster 2.7
Which Bosch and which Beru model numbers are they?
If anyone has a site where I can get them cheap I would appreciate it too. ;)
Will these work?
fgr6kqc
Loren gave you the Beru number and you have the Bosch number, for your car. I have noticed no difference between the brands when we do a plug change. Either will work and Porsche seems to switch between brands.
  • 6 months later...
What about NGK plugs BKR6EKUB for MY00 Boxster S
I was recently sent these when I asked for Boxster plugs. Will these perform correctly?
Edited by tommy914
No experience with that plug. If the 6 in the part number is the heat range then that is correct for your year.
Try them out and let us know.
