We are going to film how to replace the brake pads and change the brake fluid.
We just did it on a standard Boxster as a dry run test. Now, we are ready to video tape it.
The Boxster and 996 will be side-to-side as we film the brake work for the DVD set.
I need a 996. Send me an email. Jeff
  • 10 months later...
Toolpants,
What happened to the this "How to replace brake pad" thread? I did not see any detailed instructions on the replacement of the brake pads and replacing the brake fluid? I have never changed one before and I'd like to know the detailed instructions + pictures if you have them. Thanks very much. <_<
We did film it on a base Boxster, including a brake fluid change. Also filmed the 30k service on a Boxster and 996. Need to sit down with Henry to see if the video is good enough for a another DVD.
