Rattle coming from drivers side when going uneven roads. Sounds like something may have come loose - roof mechanism?
Has anyone else experienced this? Car has done 6000K.
Its been into the OPC but the rattle is still there.
Any suggestions on how I might fix it myself?
It could be the flocking panel which is the plastic under the canvas on the front of the roof.
The mechanism could need lubrication also and a top adjustment may be needed.
The car has 6000 mi or km? Do you park it under the sun? Excess heat can cause flocking panel to warp and make noises.
Go to another dealer if there is one.
