I have this trouble code: P1121 Oxygen Sensor Heater 2 Behind the Catalytic Converter - Below Lower Limit Value
I need to know wich O2 sensor is the one That I have to change...?
thanks
That would be cylinders 4 to 6 - which would be the passenger side of the car.
Ok Loren I have one more question..., please forgive me but english it is not my nature language and I am a little confuse with the o2 Sensors location..
Please let me know where is located the O2 sensor BEHIND the catalytic converter; This one is the one located between the catalytic and the end of the exhaust system (tail) part # 993 606 118 01....? or the one located between the catalytic and the engine part # 993 606 128 01...? thanks a lot
DC
It would be the one closest to the muffler.
The terminology is that the sensor before the cat is closest to engine and measures the bad gases - and the sensor after the cat should be seeing cleaned up gases.
Thanks Loren, you are an open book!
