Well, we had a frustrating day. I think the cruise will work OK, but the problem is the indicator light on the instrument cluster. This car has the later cluster with the new OBC display, and is radically different to the 2001 cluster. The wire which connects between Plug IV, pin 18, of the DME and Plug I, pin 16, of the cluster is not activating the cruise light. Also Fuse B7 is blowing occasionally. Obviously the connection to the cluster is wrong. Does anyone have a wiring diagram for a 2002, showing the DME and Instrument Cluster connections?
