Hi, everyone:
I have a question about warranty coverage when you install switch for either spoiler or garage door opener to the upper center console and connect it to the power source of the phone or tapped into another wire to get ground/power. Will this hack void original warranty? If yes, how can you get around to it without voiding the warranty?
Thanks in advance.
my understanding is that the dealer would have to be able to "prove" (to some extent) that your work caused the problem that they are refusing to cover. It would probably also depend upon how much they value your business, because they should realize that if they make a false claim, then you probably won't go back there.
It will not void your warranty. If you develop an oil leak they're not going to tell you to ***** up a rope because you put a switch in. I can tell you that much for sure.
