I'm wondering if I can use a rocker switch from a Targa (996 613 147 00 A 02), the one that opens the glass roof, in my 2000 Cpe. Are the rocker switches the same from year to year? I saw this switch on the "bat wing" pannel (the one that has the heated seat switches) of a targa today and the picture on it looked like a garage door to me. I figured I would order one of these instead of the door lock switch to wire my garage door opener to. Can anyone tell me if this will work? Thanks. Scott
996 613 147 00 A02 is the sun roof switch and it has three functions. One switch opens and closes the sun roof tilt. The other switch functions rock back and forth to open the sun roof (all the way) or close the sun roof. It is physically larger than any of the front console (dash) panel switches. So, it would not fit in the batwing.
996 613 157 10 A05 is the Targa Roof switch which normally resides in the batwing. So, it would fit. It is a rocker that opens the Targa roof in one direction and closes in the other. So, you could just wire one side of the switch. Now for the bad news. The Targa Roof switch only comes in the A05 black matt finish whereas all the other switches in your car (and all MY 99-01 cars) are glossy black finish.
I like the rear window wiper switch. It doesn't look much like a garage door, but it has separate illumination and contact circuits (but no function LED).
  • 2 months later...
I used the Targa "shade" switch to hook to my garage door opener and installed it into one of the blanks to the rear of the ashtray in the console. I used it because I too think it lools like a garage door. Fortunately it matches my '03 interior. I hooked one of the wires from the garage door opener to the switch's center terminal and hooked the other wire to both of the other terminals to allow it to function no matter which way I rock the switch. I also got power from the ashtray illumination lead and lit the switch by attaching those wires to the outside-most terminals on the switch.
It works great and looks great. Good luck with yours.
Dwayne
What is a good switch to use for the OBC hack. I want to do the garage hack and the OBC hack and will use the Targa glass for the garage hack but want a suitable switch for the OBC.
Thanks all,
Bobby
Kirby - It Looks Really Cool B)
So now you WILL have to swap your switch out... :thumbup:
I think I have taken the photo of the switch upside down! - Thats how it is going in my dash though...
Part No: 996 613 119 10 A05 - Note the Matt Finish! - Targa Blind Switch
Switch has illumination but No provision for a LED 'ON' indicator, but I ain't fussed about that.
Edited by ZX7R
