just notice the previous owner put 225/45 17 on front instead of the factory recommended 205/50 17. The rear is 255/40 17 like it is supposed to be. Does anyone else have this size on the front? Does anyone think this might be a problem later? I notice roadwalking in rough rutted highways if my pressure is at 29 but is a little better when I put a couple pounds more air in fronts.
225/45-17 is exactly the same diameter as the stock 205/50-17 and is a very common "upgrade".
I myself have that same combination (225 & 255) on my stock wheels.
The extra pressure up front is another nice improvement over the stock pressure and does help to crispen up turn-in.
Graeme
