Is there some way I can reduce the heat transfer from the engine to the rear trunk? I am a semi-pro musician in my spare time and it gets too warm back there to keep a stringed instrument. Would installing some heat shielding inside the trunk help or would that be a detriment to the motor? Actually, I'd love to be able to run some kind of conduit from the A/C to the trunk to keep it cool.
Regards,
Mike
You won't hurt the motor by insulating or cooling the rear trunk - the heat is 99% from the muffler which is right under the rear trunk. Above the muffler is a formed sheet of aluminium? backed by about 1/2inch of fiberglass insulation. You could probably add another 3/4 of insulation above the muffler, but I don't know how much difference another R-3? would make.
Running your existing A/C to the trunk would be difficult and probably expensive.
If a folded blanket inside the trunk under your instrument case does help enough, you might try a standalone cooling system, like a 'cool shirt'. http://www.coolshirt.net/home.htm
That's why mine has to go in the passenger seat with the seatbelt on to keep it from sliding and scratching the interior. May be your only choice.
quote=deliriousga,Oct 11 2005, 11:31 AM]
My drums fit in the front trunk :D
Joricover.jpg[
