I have a 2003 C4 Cab.
Lately, I hear noises coming from the doors around the door handle area when I am driving. Has anybody else had this problem and how did you guys resolve it.
Is this a problem I should go to my dealers with?
Peter Liao
Since your car is still under warranty you might as well let the dealer fix this. This is a known problem on some cars -- refer them to TSB 01/02 5717 Noises in Door Lock Area (dated 8-16-02) and/or TSB 3/00 7059 Noises In The Door/Door Trim Panel Area (dated 6-30-00).
FWIW, you may also want to have them check where the door (lock) meets the catch or striker (latch) on the car. Both myself and a buddy had trouble with noise from that area. Turned out that it was basically set too low (or too high) and it was rubbing/rattling from there.
A couple of minutes with a torq and problem fixed!
Mark J.
