Yesterday I replaced the ignition switch (Boxster '98 90K miles). Key moves freely now and problem with starter keeping-on after engine starts seems to be solved.
(Thanks deliriousga for your help :cheers: )
New problem: as soon as I reconnected the battery cable, the door on the driver's side does not open from the outside :unsure:
Passenger door ok, driver side ok from inside, behabes like locked but can't be unlocked with the key or remote.
I imagine that this is completely unrelated problem to the ignition switch - what could be wrong?
A diagram of the door/lock mechanism could help as well as instructions to remove the door pannel.
Door also locks and unlocks with remote or key -meaning that two pools from the inside handle are needed when locked, one when unlocked. <_<
