I am looking to replace the standard brake lines on my 99 Boxster with SS DOT approved ones. I am not having much luck finding some here in the USA for a good price. I have found some on pelicanparts but not really anywhere else. Can any of you recommend a place to me? thanks in advance.
I see the braided steel lines for a stock base Boxster at STOPTECH
www.stoptech.com
Stainless Steel Brake Lines
Line Kit for Stock Calipers
Part Number Options Price Qty
85-130-4500 FRONT $59.00
85-130-4500 REAR $59.00
These are much more expensive than at Pelican
OEM Rubber Brake Hose, Front Or Rear, 4 Per Car, 996/996 Turbo (1999-04), Boxster/Boxster S (1997-04), Each
T-355-139-01
(OEM: 996-355-139-01) $18.80
Stainless Steel Brake Hose Kit, Set Of Four Hoses, DOT Approved, 996/996 Turbo (1999-04), Boxster/Boxster S (1997-04)
PEL996-SSDOT1 $69.95
Stainless Steel Brake Hose Kit, Set Of Four Hoses, Non-DOT Approved, 996/996 Turbo (1999-04), Boxster/Boxster S (1997-04)
PEL996-SS-NDOT2 $66.75
$70 for 4 hoses doesn't sound expensive to me, but I would probably buy the $19 OEM hoses. IMO the stock brake lines are flexible and strong enough to do the job - braided steel lines are a cosmetic rather than performance upgrade.
For brake fade my sequence of upgrades would be:
* Bleed brakes every 6 months - with speed bleeders, a one person job
* Upgrade your brake fluid
* Practise more selective braking - Lime Rock is good for this:)
* Install Big Brake Kit or Boxster S front brakes
