Did you order springs for your model year or go for a later year (more weight)?
Also did anyone order the 030 springs for a Tip model and put on a Manual car?
from what I looked up in PET, fronts are the same, rear's are different part #'s for Tip cars.
What model of shocks did you use? ROW factory Bilstein's?, aftermarket Sport Bilsteins, ? etc?
Sway Bars? ROW 030's? Aftermarket? and sizes?
planning for mods when I put the car away for winter.
THx,
Mike M
02 986S
AS/GG/GG
I'd say you have 3 choices.
1. ROW M030. If you go this route, just contact Suncoast Porsche and get the whole enchilada.
2. H&R coilovers.
3. Blistein PSS9
Whatever route you take, unless you have prior experience with suspension setup, I'd go with a turnkey package. When you start the mix 'n match process, unless you really, really, know what you are doing, you'll almost certainly end up with a slower less easy to drive car.
Just IMHO,
Graeme
PSS9 - The 'performance' solution . A favorite of Track & Autocross enthusiasts, unless restricted to a lesser setup to stay in a certain competitive class
M030 - The 'stock' solution that satisfies most competitve rules
H&R coilovers - The 'budget' solution - Lowers the car to give smaller wheel well gaps - upgraded handling vs stock (non 030) suspension.
This is what I hear from others. I ordered my car with US 030 and 18" wheels - The suspension and car are still more capable off handling the road than I am as a driver.
If you want a more highly tuned suspension than one of theses 'standard' solutions, I recommend you buy Mike Lansky's race car. You will probably spend less on buying his whole 3.4L GT3 boxster than you will doing test-and-tune on all the various combinations of sway bars, GT3 drop links, springs, etc.
What happens to your money AFTER you buy a race car is something entirely different :) :)
