Assuming you have a stock 986 spoiler:
If you raise the spoiler, and can move one end of the spoiler up/down/front/back, you have probably loosened one of the 2 bolts that attach the spoiler.
to remove/reattach spoiler first remove 3 plastic rivets on the side of spoiler near the top. This is done by pushing the center of the plastic rivets and then prying out.
Pulling up the painted piece will reveal a boxy metal structure
Your loose bolt will be a hex head bolt about 1 inch below the surface of the boxy structure accessible by a circular hole near each end.
Once Loren posts the picture, this will all make sense :)
Good luck
