I currently own a 2000 Boxster with the factory litronic headlights installed. In the next week, I will be purchasing a 2001 Boxster S that has the standard halogens. Is it possible to swap the headlights? I know I will lose the auto-height adjustment of the litronics because the 2001 Boxster S does not have the servos, and that is fine with me.
You can swap the headlights. The other thing you will not have is the beam rotation. But others have managed without this feature.
You will also need to get clear triangles without the hole for the washer for the 2001 unless you are going to use the amber ones.
Since your 2000 has washers you will need amber triangles with the hole unless you are going to use the clear ones.
